Re: Farmall Super A Govenor Adjustment help
Posted by Haas on December 06, 2001 at 05:51:16 from (129.37.117.98):
In Reply to: Farmall Super A Govenor Adjustment help posted by Marty Scholl on December 05, 2001 at 23:05:25:
To adjust the linkage between the governor and the carb: 1) with engine stopped, put the throttle to wide open position. 2) Take the pin out of the clevis on the rod that goes to the carb. 3) hold the rod and the rockshaft arm on the governor as far back as they will go. This is throttle wide open. 4) With rod and throttle held like in three, adjust the clevis so that the holes in the clevis and the rock shaft arm line up and the pin will slide in freely. 5. The linkage from governor to carb must move freely without binding. 6. You adjust the high idle speed with the screw on top of the governor. If you are going to do that, you need a tachometer to tell the engine speed. High idle speed (throttle lever at max and no load) is supposed to be 1540 rpm. Turn the screw out to increase speed, in to reduce. 7. If you have surging, that is adjusted with the screw on the bottom. The screw is under the acorn nut. Screw it in just far enough to stop the surging. 8. All linkages must work freely and have minimum play in them. If these adjustments don't work, then you have worn bearings, broken or weak springs, or something like that. In other words, your governor needs a rebuild.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
