Re: Re: Re: Farmall H Belly Pump Leaking
Posted by Pawnee on December 06, 2001 at 10:50:45 from (207.51.255.129):
In Reply to: Re: Re: Farmall H Belly Pump Leaking posted by Will@ont.ca on December 05, 2001 at 23:37:38:
Will i have an SM but i would assume that the pumps are the same as far as the mechanical aspects, so how do you disconnect the countershaft? Other than the four bolts and the fittings, hoses and lever is there anything else that needs to be disconnected or unbolted?
Post A Followup
: Re: Re: Re: Re: Farmall H Belly Pump Leaking
