Re: 1950 Cub that won't start
Posted by Bigdog on December 06, 2001 at 10:53:24 from (216.255.10.241):
In Reply to: 1950 Cub that won't start posted by Andy Higgins on December 06, 2001 at 09:21:07:
You might consider running a compression test. Have you removed the fuel line at the carb to check for adequate fuel flow?
Post A Followup
: Re: Re: 1950 Cub that won't start
