Re: 1950 Cub that won't start
Posted by George Willer on December 06, 2001 at 14:51:49 from (64.254.131.110):
In Reply to: 1950 Cub that won't start posted by Andy Higgins on December 06, 2001 at 09:21:07:
Stuck valves are always a possibility. I ran into them with an engine that had just had the valves re-done a few weeks before. I also found 3 stuck valves on the current project that had sat for an unknown period.
It is really easy to check. Do so. Remove all the plugs, and hold a thumb over each hole while cranking through 2 revolutions. Any cylinder that doesn't push your thumb off probably has a stuck valve. If an exhaust valve is stuck, the engine can still start and run poorly, but if an intake is stuck...no way can it run.
George Willer
Post A Followup
: Re: Re: 1950 Cub that won't start
