Re: hydraulic hoses on new saginaw 3 point
Posted by Chris J on December 06, 2001 at 18:46:32 from (24.166.92.4):
In Reply to: hydraulic hoses on new saginaw 3 point posted by Zeke on December 06, 2001 at 18:02:15:
You should probably hook the 2 bottom ports of the cylinders together with a "T", the 2 tops together with a "T", and then put a connector on each "T" to connect to the hoses. Run one hose from pressure fitting to the "T" from the bottom of the cylinders and the other hose to the return fitting.
If pics will help, email me. If I did and the ones I sent didn't help, tell me what you need, you can have them Friday or Saturday.
Chris
Post A Followup
: Re: Re: hydraulic hoses on new saginaw 3 point
