Re: hydraulic hoses on new saginaw 3 point
Posted by Haas on December 07, 2001 at 06:22:15 from (129.37.117.176):
In Reply to: hydraulic hoses on new saginaw 3 point posted by Zeke on December 06, 2001 at 18:02:15:
You can just hook the hose from one port of the lift all through a tee to both cylinders. However, be aware that when you release the lift all rod (all the way forward), the hitch is going to fall all the way down. Then you will have to pick it back up to the work height you want. Things will work better if you install a spool valve so you can have two way control. This will give you down pressure as well as precise control of the hitch height. If you do that you will need a spool valve and a bunch more hoses. What you will do is mount the spool valve at a convenient location so you can operate it. The run a hose from the lift all port to the inlet port of the spool valve. Run a hose from the spool valve return to the fill port of the lift all. You'll probably have to install a tee on the fill port for that. Then run a hose from each of the two spool valve outlet ports to two different tees. Then two hoses from one tee to to the bottom cylinder ports and two hoses from the other tee to the top cylinder ports. To operate it then you lock the lift all in the lift postion so that fluid circulates through the spool valve all the time that the lift all pump is running. This is really no different than normal operation of the lift all, since pressure is only generated with this set up when you work the spool valve.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
