Re: D239 piston rings
Posted by IH-NEAL on December 07, 2001 at 06:26:25 from (216.165.147.8):
In Reply to: D239 piston rings posted by Stan S. on December 07, 2001 at 06:13:17:
Stan, I believe what happened is they got the wrong ring set for those pistons. They made a number of changes on those rings and pistons. If you do the job over, make sure to get the right rings. Some of them had a double taper. WE had a fellow do one in the shop one year about this same time. Guess what? He put them them in the groove with taper opposite to the taper in the piston groove. You want to talk about smoke. I couldn't believe it even started. Good luck and Merry Christmas to all.
Post A Followup
: Re: Re: D239 piston rings
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
