Re: Help settle an argument ?
Posted by George Willer on December 07, 2001 at 08:25:19 from (64.254.131.24):
In Reply to: Help settle an argument ? posted by sHan on December 07, 2001 at 08:13:02:
Usually, the rear is much heavier. In your case, the loader and lack of rear weights confuse the issue, as you already know. You can easily determine the true answer yourself. Hook up your trailer to the truck and carefully measure the bumper height. (on level ground) Load the tractor and adjust it back and forth till the bumper is at the same height. The tractor is now balanced, centered over the axle, or pair of axles. Simple measurement will give the answer.
George Willer
Post A Followup
: Re: Re: Help settle an argument ?
