Re: Exhaust Lift????
Posted by Jim Becker on December 09, 2001 at 20:29:43 from (4.61.16.38):
In Reply to: Exhaust Lift???? posted by Ed Fleming on December 09, 2001 at 16:53:53:
I'll assume the engine itself is in basicly decent shape. The most likely problem is the pressure valve on top of the exhause manifold. Run the engine wide open and latch the lift lever back. What happens? It should be able to stall the engine. If not, where is the exhaust coming out? Out the exhaust pipe, fix the pressure valve. Out anywhere else, fix the leak. If no leaks, either something is mechanicly jammed or the control valve is blocking. The control valve is near the oil filter. Corrosion can cause problems. There is also a neoprene washer in there that can cause problems if it is swolled or otherwise deteriorated.
Post A Followup
: Re: Re: Exhaust Lift????
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
