Radiator cap, is it usable?
Posted by SAm on December 10, 2001 at 03:30:50 from (24.138.19.199):
The radiator cap for my Super A is in two bits. The outer part that is the actual cap and then the inner bit with the rubber seals on it. Both bits appear to be in reasonable shape and I can see no reason why it shouldn't work but I was wondering if it was going to cause problems? Thanks in advance.
Post A Followup
: Re: Radiator cap, is it usable?
