Re: can you flip the fan over on an H/M??
Posted by Ron on December 10, 2001 at 08:14:46 from (155.226.255.42):
In Reply to: can you flip the fan over on an H/M?? posted by Steven@nd on December 10, 2001 at 07:16:12:
Steven,
Bob is right. To make this work the way you want it to, you would need to rotate the fan in the opposite direction and if the fan is mounted on the water pump like many (or most) are, then that would cause water flow problems. For winter use, you might be OK just removing the fan as long as the tractor load is light.
Post A Followup
: Re: Re: can you flip the fan over on an H/M??
