Re: Farmall Mag or Distributor? Whats better?
Posted by Haas on December 11, 2001 at 06:03:48 from (129.37.117.137):
In Reply to: Farmall Mag or Distributor? Whats better? posted by Plow Man on December 10, 2001 at 21:11:32:
You should be able to get all the parts you need to fix your distributor. If you can't, rebuilt ones are available. As to the magneto versus battery ignition. The IH magnetos indeed do not have spark advance. But unless you are into pulling or something like that, it doesn't make much difference. You can also get all the parts you need for the mag. I have two tractors that have IH H-4 magnetos. I don't think anything much has been done to either and they are both over 50 years old and they still start and run fine. I did put new points and condenser in one and just new points in the other because I did not want to bother taking the mag off. The condenser in the one I changed looked like it was original. The advantage of the magneto is that it requires no electricity from a battery to run. If the battery goes down you keep on going. Or you can crank or pull start and you are going. The advantage of the distributor is as mentioned before, you have spark advance, and also you get a hotter spark for starting which makes starting much easier. However, with 12 volts on the starter, I've had no trouble getting the tractors with magnetos to start easily. I've even thought about converting the tractor I have with the battery ignition to a magneto. I think it would look better because the battery ignition does not have an original coil and so far, I have not been able to locate a coil that looks original.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
