Re: 560 head gasket leaking comp on push rod side
Posted by todd08 on December 11, 2001 at 09:38:06 from (199.240.181.94):
In Reply to: 560 head gasket leaking comp on push rod side posted by todd08 on December 10, 2001 at 20:07:40:
Thanks guys for the good info, I certainly agree with retorqueing the head gasket after run awhile, and I bet I will need a surface job
Post A Followup
: Re: Re: 560 head gasket leaking comp on push rod side
