Re: 300 U hyd.
Posted by TomT on December 11, 2001 at 13:17:51 from (162.42.198.210):
In Reply to: 300 U hyd. posted by ironhead on December 11, 2001 at 12:47:00:
Both 300 U's that I have owned had water in the hydraulic oil and I live in the desert! I have since learned from this forum that many hydraulic oils have an affinity for water. How it gets in is a little more of a mystery, but you will notice that none of the bolts over the reservoir are water tight, plus there is condensation, ect. In the future, I have used denatured alcohol with some success for limited moisture removal. Finally, the drain plug is on the left hand side of the reservoir, often hidden by the lifting cylinder. Good luck
Post A Followup
: Re: Re: 300 U hyd.
