Re: Re: 300 U hyd.
Posted by TomT on December 11, 2001 at 14:24:30 from (162.42.198.210):
In Reply to: Re: 300 U hyd. posted by big fred on December 11, 2001 at 13:33:16:
Big Fred is right, I forgot about the breather. If you need to find it, look under the seat. It's probably shaped like a small cylinder a couple of inches long mounted horizontally. Clean it well and keep it tight as Big Fred suggested.
Post A Followup
: Re: Re: Re: 300 U hyd.
