Re: Farmall H with stuck engine again.....
Posted by John on December 11, 2001 at 17:21:41 from (209.240.222.132):
In Reply to: Farmall H with stuck engine again..... posted by Steven@nd on December 11, 2001 at 07:31:30:
I think the price is fair, but you can always try to deal on it.
I would suggest if possible, pull out the spark plugs and look for a lot of rust deposits could mean some water leaking into the cylinders. I have seen an exhaust pipe covered up and still have some water in the cylinders. Sometimes the are not covered originally. Another thing to do is check the oil, loosen up the drain plug
If water runs out or antifreeze, there may be an internal leak. a little water will not bother much because it is probably just some condensation.. A little extra time spent before you buy will save any regrets later. I have been there. Sometimes a person selling a tractor will be happy to find out more themselves.
Post A Followup
: Re: Re: Farmall H with stuck engine again.....
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
