Re: 300 U hyd.
Posted by Jim on December 12, 2001 at 03:54:41 from (12.87.72.3):
In Reply to: 300 U hyd. posted by ironhead on December 11, 2001 at 12:47:00:
The drain plug is on the left side, as you set in seat, if you have a Fast hitch it is hiden by hyd. cylinder, or mount, that raises the hitch.
Post A Followup
: Re: Re: 300 U hyd.
