Re: Hydraulic Ports On C??
Posted by Jim Becker on December 12, 2001 at 13:08:01 from (4.61.16.38):
In Reply to: Hydraulic Ports On C?? posted by 1PWRFULH on December 11, 2001 at 16:39:13:
Do you need to use the Touch Control at the same time? If not, here is the quick way to hook up a remore valve.
Hook a hose into the high pressure tap on the Touch Control manifold (same place everyone else is talking about). Run this to the inlet of a valve. Run the return from the valve into the filler of the Touch Control reservoir. Hook your cylinder to the valve in the usual fashion.
Run one of your Touch Control arms all the way to one end or the other of its stroke. Take a piece of chain and tie the arm in place. Move the control handle for that arm all the way the other way and leave it there.
Post A Followup
: Re: Re: Hydraulic Ports On C??
