Re: Re: Re: Hydraulic Ports On C??
Posted by Haas on December 12, 2001 at 13:32:42 from (129.37.117.197):
In Reply to: Re: Re: Hydraulic Ports On C?? posted by Clyde on December 12, 2001 at 10:59:09:
I've not seen the block that is added, but I would think the pressure side of the block could not have a hole straight through. The suction side of the block needs to have a hole straight through. The pressure side would need to have a hole drilled part way through from the Touch Control unit side and then another hole at right angles which comes out for you to attach the return from the remote valve. That way all the flow from the pump goes through the remote valve all the time, but the Touch Control still has the same supply it always had except when you operate the remote valve.
Post A Followup
: Re: Re: Re: Re: Hydraulic Ports On C??
