Re: charge/discharge
Posted by Bigdog on December 13, 2001 at 07:10:42 from (157.254.96.131):
In Reply to: charge/discharge posted by KLAW on December 13, 2001 at 05:21:54:
Red Dave is right. If the ammeter deflects to the positive when you turn the lights on with the engine not running, it is either backwards or someone has installed the battery backwards. The positive post goes to ground on those 6 volt cubs. If someone has converted it to 12 volts with an alternator, then it the battery should have the negative post to ground and the ammeter wires should have been reversed.
Post A Followup
: Re: Re: charge/discharge
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
