Farmall Tractors Discussion Board
international 444
Posted by dan on March 13, 1999 at 10:52:11:
My 444 stalled out and would not re-start. Acts like it is not getting gas. Will run on starting fluid if sprayed in air intake, but wont pull gas through. Fuel line to carb is clear. What gives? Is the fuel pump shot? Is the carb gummed up? How can I test to find out?
Post a Followup
: Re: international 444
