Re: Re: Re: counter shaft seal on H
Posted by Zonie on December 13, 2001 at 22:53:38 from (152.163.204.72):
In Reply to: Re: Re: counter shaft seal on H posted by Speed Bump on December 13, 2001 at 21:03:44:
I just had to pull the same seal out this morning on my H. I used a brass punch and hammer to turn the nut enough to get it loose. It wasn't too hard to do. I think I turned counter clock wise but I'm not positive of that.
I had to order the seals from a bearing and seal supply house. It will take 2 each 13602 seals, the old seal type is not available any longer.
Get the new seals befor you take the old one out as gear oil will run out.
Post A Followup
: Re: Re: Re: Re: counter shaft seal on H
