Farmall Tractors Discussion Board
Re: Fluid in tires (Farmall H)
Posted by Iron man on March 13, 1999 at 12:14:48:
In Reply to: Fluid in tires (Farmall H) posted by jr on March 11, 1999 at 16:38:34:
I work on heavy equipment for a living and have aquired quit abit of used antifreeze. I installed it in the tires of my 340 utility works great was cheaper for me. And it's not nearly as corrorsive as calsium as far as weight it's not quit as heavy but i don't belive you will see the diffrence
Post a Followup
: Re: Re: Fluid in tires (Farmall H)
