Re: hydralics, super c
Posted by Haas on December 16, 2001 at 10:50:14 from (129.37.117.38):
In Reply to: hydralics, super c posted by waterpirate on December 15, 2001 at 16:47:03:
I believe there is a relief hole to let fluid that gets past the endplate of the pump to the seal area flow back to the low pressure side. If that hole is stopped up, or the pump is not put together correctly, the seal can see high pressure. That will blow the seal in short order. Also wear in the pump could put too much fluid pressure on the seal(exceeding the bleed capacity) and cause it to blow.
Post A Followup
: Re: Re: hydralics, super c
