Re: H front wheel assembly
Posted by Michael Soldan on December 16, 2001 at 11:37:02 from (216.46.130.66):
In Reply to: H front wheel assembly posted by Rob Mo. on December 15, 2001 at 20:00:52:
Rob , Wayne is corect in removing the rim from the wheel. I usually run the H up on a couple of boards with the one wheel so that the one I intend to remove is off the ground, you don't even need a jack. Loosen the bolts first and run her up on a couple of boards or a 2x4. Remember how the wheel was on because you can install H fronts to widen them out or in for various row crops by the way you put them on the wheel, lug inside or outside, lug reversed inside or outside, thus 4 different widths...good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: H front wheel assembly
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
