Re: Plow points
Posted by The Red Baron on December 16, 2001 at 17:01:11 from (198.81.17.156):
In Reply to: Plow points posted by Keiren on December 16, 2001 at 12:32:52:
I'm not sure if this will work for you or not, but we bought an old plow which badly needed a new share. I had no idea what to get until the friendly dealer told me to take it off and see what part number was stamped on the reverse side where the metal to metal contact protected it from being worn away. He was quickly able to get it or any of about a dozen different styles depending on soil conditions you will be using it under.
Post A Followup
: Re: Re: Plow points
