Re: Re: Magneto problem
Posted by walt f on December 16, 2001 at 20:26:42 from (24.159.78.155):
In Reply to: Re: Magneto problem posted by walt f on December 16, 2001 at 15:25:53:
you haven't changed anything since the tractor last ran? if not then verify that you've got spark by putting a piece of copper wire in one of the plug holes and turning it toward the engine block, but away from it about 1/8 in. i use a piece of wire like you would find in a piece of romax or house wire like in the walls, 12 guage wire skinned back a half in. on one end, then turned back and pressed in the plug tower, the other end turned toward the block for the spark to jump across the 1/8 in gap. i use the stiff wire so i don't have to hold it when it aparks. when i crank the engine over i look for the spark to occur every fourth snap of the impulse in the magneto. no spark? then i try to get the tip of the stiff wire as close as possible and try again. still no spark, then i open up the magneto to inspect the points to see if they are opening. (here you should go over to the allis chalmers board to ask for help because the allis tractors almost exclusively use the fairbanks morse magnetos). if you've got spark, and it's good fat white at 1/4 in. then check for fuel, take out one of the spark plugs to see if its wet, no then see if you can see the obvious. open the drain plug on the carb and drain it into a small clean coffee can and notice if it flows non stop for a min. look down in the can to see if there is water in the gas. if it's been in there long then the water will be rust colored, this is bad because the carb. is cast iron and the rust will clog the jets. turn the gas drain plug off after a min. if it's clean then pour it back in the tank. if you have fuel and spark then you will get fire, mabey back fire, in which case you will need to check the firing order. hope i've helped.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
