Re: Re: Re: Re: Re: Lead additive
Posted by Jim Becker on December 17, 2001 at 07:09:37 from (4.61.16.38):
In Reply to: Re: Re: Re: Re: Lead additive posted by Bill Jones on December 16, 2001 at 22:18:29:
I think you got a bit crossed up on your definition of supercharger vs. turbosupercharger. Supercharger is the more general term, but is usually applied to a mechanically driven compressor. The dragsters with a GM blower, driven by a belt with a carburetor on top are an example. A turbosupercharger is one where the compressor is powered by an exhaust driven turbine, hence the prefix "turbo." There were several factory installations of this type back in the '60s. As far as I know, all of these compressors worked on the mixture after it came out of the carburetor (which would fit your defintion of "internally driven").
Post A Followup
: Re: Re: Re: Re: Re: Re: Lead additive
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
