Re: Rebuilding an Ensign regulator and carb?
Posted by IHank on December 18, 2001 at 17:04:35 from (216.51.140.154):
In Reply to: Rebuilding an Ensign regulator and carb? posted by Cliff Neubauer on December 18, 2001 at 14:51:52:
Cliff- Suggest you inquire of your LP supplier and get contact with his supplier and mebbie even another level up.
Long ago I found that the local supplier tended to keep things as simple as possible and that sometimes left a customer wondering what to do and were to go to get something repaired.
Look around your area and see what you can find. If there's just no help available clik on my private e-mail and I'll try to connect you to a Central Iowa firm that might be able to supply what you need. Good luck, IHank in Iowa
Post A Followup
: Re: Re: Rebuilding an Ensign regulator and carb?
