Re: Re: Re: Jim Becker
Posted by Jim Becker on December 19, 2001 at 07:47:48 from (4.61.16.38):
In Reply to: Re: Re: Jim Becker posted by Bill Jones on December 18, 2001 at 21:22:43:
I guess one could say that a lot of external superchargers are turbos. But the GM Diesels are a fairly major exception. To say that most,if not all external supers are turbos is probably true in the aviation world. In the '60s, there were a few turbochargers that got automotive use. The Chevy Corvair and Oldsmobile F-85 both had turbos available from about the same time. The IH Scout was available with a turbo a bit later. This web page: http://www.corvaircorsa.com/turbo02.html has a picture and description of the Corvair unit. You can see that the tubrocharger is mounted after the carburetor. That page has a reference to a homemade conversion that put carburetors after the compressor (thus becoming an external supercharger). This page shows it: http://www.corvaircorsa.com/binnie03.html If you look at that page, it hints at some of the problems inherent in making that change. The main ones are modifications required to the carburetors themselves. To get by the pressurized venturi area problem that I mentioned in an earlier post, he is pressurizing the carburetor bowl with the boost pressure. Then he had to use a higher pressure fuel pump (with pressure regulation) in order to keep fuel flowing into the bowl. These don't sound that major, but try finding suitable components out of a 1960's standard parts catalog. The Corvair unit was pretty simple. There was no waste gate. Pressure was limited only by the inherent design of the system. Engine speed had to be fairly high before positive manifold pressure showed. There was no water injection either. A pressure retard was used on the distributor to back the spark off at higher pressures. I don't know much about the Olds or Scout systems, I presume they were similar. The Olds did have a water injection system and probably a waste gate. There were aftermarket supercharger kits available in the '60s as well. I know there was at least one belt driven supercharger (Paxton maybe) that basicly put the entire carburetor inside a pressurized box. That way they avoided any carburetor modifications (other than maybe jets). But they still needed a higher pressure fuel pump. That too would be an example of an external supercharger that is not a turbo. The next round of turbocharged passenger cars must have started in the mid/late '70s. At that point, port fuel injection was starting to come into play. So I would guess most, if not all, of those would qualify as external superchargers. Those injection systems could produce enough pressure to not be impacted much by the supercharger air pressure.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
