Re: Split tractor needs help!
Posted by right said fred on December 19, 2001 at 11:54:23 from (12.81.199.231):
In Reply to: Split tractor needs help! posted by Robert on December 18, 2001 at 17:04:25:
The key here is alignment, alignment, and alignment. The gap between the engine and trans housing should be equal all the way around as you bring the two halves together. Eyeball it carefully, measure it, get it as equal as you can. Move and jack it as needed. Use longer bolts in the attachment area to guide you. Turn the pto shaft or engine to help line up the splines between engine and clutch disc. With the two halves lined up as close as you can, tighten them some as you turn the engine/tranny. I've had to tighten some quite a bit before they popped. It is part of the skill of a mechanic to know how much to tighten before you hurt the clutch disc. If it just won't go, you might have to roll the halves apart and examine. You need to check clutch disc spline to tranny input shaft before you assemble. Same check for pilot bearing to tranny input shaft--sometimes one gets sold the wrong parts. These are the two things that have to go together, along with an ipto shaft, if so equipped.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
