Re: Split tractor needs help!
Posted by the tractor vet on December 19, 2001 at 13:21:34 from (216.196.13.153):
In Reply to: Split tractor needs help! posted by Robert on December 18, 2001 at 17:04:25:
Like was posted before put the prussure plat on the main shaft and install the disc on the input shaft then slide the tractor back togeather work through the inspection hole in the bottom to put the bolts in the prussure plate to flywheel it work better then any othere way . besides you can lay down on the job!!!!
Post A Followup
: Re: Re: Split tractor needs help!
