Re: Farmall H Engine
Posted by Pete on December 19, 2001 at 18:48:13 from (66.24.154.149):
In Reply to: Farmall H Engine posted by Leroy Simonson on December 19, 2001 at 18:40:29:
Leroy, is the piece out of the actual cylinder wall, or the piston sleeve (the line that sets in the block?) if it is the sleeve, chances are you'll be ok with a new sleeve, although if you're in that far, I'd put all new sleeves, pistons, rings, wrist pins, rod and main bearings, and have the rods and crank worked, and do a valve job. Pete
Post A Followup
: Re: Re: Farmall H Engine
