Re: Engine Sleeves and Pistons
Posted by Stan(VA). on December 20, 2001 at 04:54:21 from (207.172.109.14):
In Reply to: Engine Sleeves and Pistons posted by Bob D on December 19, 2001 at 15:03:40:
If you're doing an in-place overhaul, get a dial caliper and check your crankshaft journel sizes to verify that it is worth putting together without grinding the crank. You can replace the main inserts while the crank is in place. They usually just come in std sizes, where the rods you can often get in a .002 for slightly worn shafts. I'm assuming you'll do the rods while they're out anyways. Otherwise the end gap of the rings needs to be checked. Put them in one at a time in the top of the cylinder leveling them with the piston and check with a feeler gauge. File the ends down and re-check if too tight. Take the rods to a machine shop with a new piston pin and let them install the new rod bushings and size them to fit the pins. If you're not having the valves done, at leaste clean all the carbon out and look for damage or thin valves that might be trouble later. Clean out any sludge that you can get to in the block and head. Make sure you have no plugged oil drain returns. Then remember to replace the oil after the first couple hours. Random ramble mode off ;) Hope it helps, Stan(VA).
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
