Re: 44A Finally Charging!!
Posted by Haas on December 20, 2001 at 05:12:40 from (129.37.117.95):
In Reply to: 44A Finally Charging!! posted by EZHangin on December 19, 2001 at 17:14:23:
If your battery was 12.2 volts without the engine running, it was low and you can expect it to show charge on the ammeter for quite a while. A fully charged good battery should show about 12.7 volts without the engine running. The 14 volts or so is normal for the alternator, but as the battery becomes fully charged, the amps will drop off to near zero.
Post A Followup
: Re: Re: 44A Finally Charging!!
