If it has enough power to turn the engine, you should have enough to produce a spark [and completely irrelevant with a mag).
But, at the risk of stating the obvious, you're not getting fuel, spark, or maybe compression [if you're borderline there, a week battery won't spin it fast enough to pull in a good mixture or compress it as well either].
Soooo; after a few months, I'd suspect points or needle valve. Least messy (especially if you have an assitant) pull a plug wire and check for spark. If that's good, do you smell gas at the exhaust when it cranks? No? See if that carb is getting gas, if it doesn't have gas, it could be stuck needle valve, plugged line or bowl, [is the gas above the standpipe? BTW].
Well a couple obvious directions anyway; I don't have my H anymore, but that one and several others I've tinkered with were always pretty forgiving if they had gas in the carb and spark at the plugs.
This post was edited by spiffy1 at 09:09:45 03/16/09.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
