Re: help, h pops out of time!!
Posted by Theman on December 21, 2001 at 07:32:47 from (12.19.86.5):
In Reply to: help, h pops out of time!! posted by IHpuller on December 19, 2001 at 18:19:01:
Gas shouldn't be coming out of the carburetor unless you are choking it too much trying to start it. If you aren't closing the choke and have gas running out you have a float valve problem. It sounds like the engine is flooding and the time you take to get it back "in time" is giving the cylinders a chance to clear up. As far as timing the engine to the pulley, there is a key to time the front pulley to the crankshaft. Unless the woodruff key was left out completely, it shouldn't be in any other position. The correct timing mark for top dead center is the first of the double notches on the front pulley to come in alignment with the pointer on the timing gear cover. The single notch on that pulley aligns the pilot bearing grease fitting in the flywheel with a hole in the bottom of the clutch housing. To help locate what is moving out of time, use an ink marker to note the slot that drives your magneto. You can put a dot on the face where the mag mounts. You have to remove the mag (again) to do this. To save a step later, put a mark on the corresponding drive tang on the magneto just to make sure it is staying properly engaged. If, when you have this problem again, you can know if something inside the engine is moving out of place. If that checks out OK, the mag is causing the mis-timing. Post back with a new posting what you find.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
