Re: 560 D has miss
Posted by the tractor vet on December 21, 2001 at 20:07:24 from (216.196.13.31):
In Reply to: 560 D has miss posted by Biian in MO on December 21, 2001 at 19:44:28:
It is posable that you have a valve that is stuck open or that one is stuck closed and maybe that when you ran the engine it broke a push rod, It is not hard to pull the valve cover and check everything and it would be a good time to adjust the valves i'll bet that they could use it.
Post A Followup
: Re: Re: 560 D has miss
