Re: farmall H is fouling plugs
Posted by andy on December 21, 2001 at 21:13:55 from (66.43.222.11):
In Reply to: farmall H is fouling plugs posted by Brad on December 21, 2001 at 08:16:19:
My Farmall 706 was fouling plugs. I changed plugs and then even changed to a hotter plug. Changed gas, added heavier oil all to no solution. It looked like a diesel sitting there running the corn dryer. Finally, I pulled the air cleaner out and found the air intake to the filter was full of leaves, grass, etc. This caused a huge vacume on the cylinders which caused the oil to be drawn up along the piston and sleeve. It drank oil! Only the Champion 21 plugs would work. After I cleaned the intake pipe everything worked fine. I have heard of the old oil bath aircleaners getting filled up with dirt and deposites. Just a chance. Goodluck
Post A Followup
: Re: Re: farmall H is fouling plugs
