Re: Low range A
Posted by justin on December 21, 2001 at 22:42:31 from (209.23.129.46):
In Reply to: Low range A posted by Nemo on December 21, 2001 at 20:50:01:
IH used what was called a hydra-creeper to achieve low low speed in the Super A. This basically was an attachment that went on the PTO of the tractor, and used a hydraulic motor attached thru the touch control to power the transmission. This set up was used in tobacco setting and other operations where low speed was needed.. The problem that you will face, is the loss of the pto shaft to operate the system.
Post A Followup
: Re: Re: Low range A
