Re: farmall H is fouling plugs
Posted by stillcrazy on December 22, 2001 at 01:10:38 from (199.82.243.76):
In Reply to: farmall H is fouling plugs posted by Brad on December 21, 2001 at 08:16:19:
Try advancing the timing a little, if the timing is slow it doesn't burn all the fuel. An old timer set me straight on this when my B was fouling plugs. Are the plugs all black and sooty? May be worth a try, Good Luck - Scott
Post A Followup
: Re: Re: farmall H is fouling plugs
