Re: tachometer does'nt work
Posted by Mark W. on December 22, 2001 at 16:10:37 from (63.168.30.40):
In Reply to: tachometer does'nt work posted by john w. on December 18, 2001 at 09:34:00:
John:
I had the same problem once with a '72 Corvette. It had two broken teeth on the tach drive gear, which was mounted in the distributor housing. I went after the broken-off teeth, and pulled FIVE teeth out of the grease in the housing! The previous owner had apparently just popped in a new gear without bothering to fish out the broken pieces. That explains the two broken teeth on his replacement gear. Bottom line -- remember to clean out that little gearbox. Good Luck.
Post A Followup
: Re: Re: tachometer does'nt work
