Re: Low range A
Posted by K-Mo on December 23, 2001 at 05:20:35 from (65.169.189.2):
In Reply to: Low range A posted by Nemo on December 21, 2001 at 20:50:01:
I have a F-140 with an Auburn trencher. It has a creeper gear box which is mounted between the transaxle and clutch housing. It makes the tractor about 8-10" longer. I gives you two creeper ranges. If you could find one of these trencher gear boxes you would have twelve speeds. Of course about 8 of these speeds would be too slow for any practical use other than trenching. Forth gear on the transmission and creeper would probably work for tilling.
K-Mo
Post A Followup
: Re: Re: Low range A
