Re: Well I got me one(finally)
Posted by Carp on December 23, 2001 at 08:54:34 from (64.89.13.200):
In Reply to: Well I got me one(finally) posted by Jack on December 23, 2001 at 06:51:04:
I would try to locate a used block. As long as your engine is OK except for the crack in the block.
Now as far as a repair, we have seen two types of repair that works. One is to drill and tap holes around the cracked area and bolt a plate over it. We have also had some luck with just welding a crack shut.
Can't do no harm by tryin to fix it first though. Can always byuy a block later if it doesn't work.
Post A Followup
: Re: Re: Well I got me one(finally)
