Re: Well I got me one(finally)
Posted by Steven@nd on December 23, 2001 at 09:32:37 from (64.68.165.69):
In Reply to: Well I got me one(finally) posted by Jack on December 23, 2001 at 06:51:04:
A good welding shop can probably weld up the cracks for you. But that will cost about the same as a replacement block and gaskets. I have welded cast iron with the old Lincoln stick welder (AC only) and some $5 a piece nickel rods. Keep the casting warm as long as possible and cool slowly. They recommend heating the casting with a torch before you start welding also - I believe this keeps it from cracking more while you weld.
Good luck and great deal!
Steven
Post A Followup
: Re: Re: Well I got me one(finally)
