Re: resistor ?
Posted by Red Dave on December 23, 2001 at 14:06:30 from (63.17.97.106):
In Reply to: resistor ? posted by Justin on December 23, 2001 at 13:38:27:
A resistor is used when a 6 volt coil is used on a 12 volt system. The resistor drops about 6 volts across itself the other 6 volts is across the coil.
If you don't use one where it is needed, the coil life will be much shorter.
Some coils have the resistor built in. If the coil is marked "12 volts" it should have the resistor inside and would not need one externally.
Post A Followup
: Re: Re: resistor ?
