Re: Under the Valve Cover of M
Posted by Farmer Bob on December 24, 2001 at 14:18:43 from (66.152.73.205):
In Reply to: Under the Valve Cover of M posted by John on December 24, 2001 at 13:01:56:
John, That pipe is a lube tube and the small hole should be at the back end of the engine. Valves should be set at .017" with engine at operating temp.//FB
Post A Followup
: Re: Re: Under the Valve Cover of M
