Re: M Oil Pump
Posted by Red Raider on December 26, 2001 at 19:46:20 from (208.188.19.170):
In Reply to: M Oil Pump posted by John on December 26, 2001 at 17:05:10:
The spring you noticed is pressure relief valve spring. After cleaning the unit in solvent, check for loose teeth, if the idler gear or body is damaged replace both. It's possible the rattle is from the gear wobbling on the idler shaft, and should be replaced. Replace the gasket which is also a shim. CaseIH has an overhaul kit that includes the gears and idler shaft. You might have them do the overhaul while in the dealership, or a machine shop that has some experience on tractor engines.
Post A Followup
: Re: Re: M Oil Pump
