Re: Re: Re: Re: 806 power steering leak (BAD LEAK)
Posted by the tractor vet on December 26, 2001 at 20:33:12 from (216.196.13.138):
In Reply to: Re: Re: Re: 806 power steering leak (BAD LEAK) posted by Cliff Neubauer on December 26, 2001 at 17:51:24:
The holes are 1/4 fine thread and i use 2 grade 8 bolts that are 6 1/2 inches long and a steering wheel puller that you can get at sears or any auto parts , to remove the seal first remove the snap ring then set the steering wheel back on but don't put the nut on and turn the steering wheel either way real fast and as hard as you can and it will pop the old seal right out. The rest is simpal.
Post A Followup
: Re: Re: Re: Re: Re: 806 power steering leak (BAD LEAK)
