Re: C Three point
Posted by Haas on December 27, 2001 at 06:22:59 from (129.37.117.130):
In Reply to: C Three point posted by Novice on December 26, 2001 at 17:48:29:
I have a C with a 3 point on it. The hitch was on it when I got it, so don't know the brand, but it is a factory made hitch. It works off the touch control rockshaft arms with bars that go back to a rear rockshaft that is part of the hitch. I don't recommend that. Not enough lift range and not enough capacity. You can lift a box blade, plow, etc, but forget anything heavy. Get one that uses a hydraulic cylinder, from Saginaw County Tractor. They have a block to go in the touch control manifold so you can use a spool valve and the hydraulic cylinder.
Post A Followup
: Re: Re: C Three point
